What tile project are you working on?
620K views 4.1K replies 216 participants last post by  TileMarbleGranite
It's been a little dead hereabouts lately, so I thought I would try and liven things up a little.
Post some pics of your current tile projects in progress. The good, the bad, and the ugly.
#1,579 · (Edited)
Nice looking floor Todd. Here is one of the four showers where helping with out in UBC. We took care of the linear drains (these drains we had made locally here in North Vancouver at my metal shop) and prepared the showers for flood tests. All showers where prepped in Noble Seal TS. All showers past flood tests and the only request from the plumbing inspector was a copy of the IAPMO Certification.
Waiting on the glass order now. Dado cut into the stone to receive the glass.
Floor is one solid piece of stone with saw cuts for increased slip resistance. Cuts where then grouted.
Not truly a barrier free but slight drop down shower. You can see the stone boys killed the install and even the threshold has a slight pitch to it.
JW
UBC Drop Down Shower
#1,581 ·
Vancouver Curbless Shower - Linear Drain Install
Here is a look at our project down in Vancouver's West End Waterfront. A master en-suite with a barrier free shower.
The tile work and stone work all set by the crew from ProCon and they are doing an amazing job. We helped with the drain installation and like most of our projects here in Vancouver brought the shower to flood test and then handed over the reins to the master setters.
It's a great crew down there - headed up by a foreman named Ed who is great to work with. Can't wait to see the floating bench go in and the glass order. The drain is a little short so I'm going to prepare some custom brushed stainless end caps.
JW
#1,582 ·
North Vancouver Curbless
Here is a look at our other active barrier free project in North Vancouver.
Setter is going "Old School" with a thin-set, mortar mix, thin-set method to level the natural stone perfectly flat.
Like the other shower above we will have grading outside the shower back into the shower.
It is hard to calculate the exact elevation gain so I held off on the shower's flood test and waterproofing until this dry zone prep work is done.
JW
#1,584 ·
JW
I think we are doing a linear drain on house we are building now. Have a favorite?
#1,585 ·
Nope. We install all of them. Clients and designers are all over the road with their likes and dislikes. Better to send them links to all the drain manufactures galleries and ask them to simply pick the strainer and then design the shower around the drain.
Some of the drains are approved as primary shower drains like the one above and others are not and need a clamping drain. Both installs can get installed tight to the back wall like but this is the hardest look to pull off.
@Brian. The wall tile Brian is a combo of glass and natural stone.
#1,586 ·
Worked late last night and prepped my buddies shower for flood test.
Check out the Neo Angle relief cut!
Sweet.
My friend helped me with a lot of boarding in my home renovation a couple years back and now I get to help him with his master ensuite.
There is of course the subject matter of ice cold beer which is appealing as well :laughing:
#1,592 ·
Looks great guys.
Man I'm getting beat up here in Vancouver my hands are trashed and both knees killing me.
To add icing to the cake I have to tile or next shower! :blink:
I have to figure a way to slip a layer of Noble Seal TS into my overalls knee pad section. I have never been able to do this.
Do any of you where Carharts? How is it done?
JW
#1,594 ·
JohnFRWhipple said:
Looks great guys.
JW
They are called knee pads John. :laughing:
#1,600 ·
Now your talking! And I love the smell of those.... before operation "Stink Bomb" take over.
So I'm going to tile this next shower with my helper David so you men can see what "Mad Skills" we have here in North Vancouver.
It will be easy!
Custom niche.
Barrier free shower
two tile sizes
flush drywall to tile transition
cast iron tub
no lash
no raymondi
Have I mentioned how slow we are when we set.... :laughing: worked 2 1/4 hours yesterday and got four tiles up. One is not set above the niche because we forgot the grinder to back miter the tile for the niche prep.
Today I hope to get up about four tiles.
I like to work in rows so I can't go that far astray and since the wall tiles are 2'x2' it will only be four days to do the walls.
Here is a peak at the work we did yesterday.
#1,601 ·
In the morning we prepped up another shower for a linear drain install downtown Vancouver. We need to firestop around the cast iron drain.
I have had these move on me before. It is very hard to tell what will happen when the spray foam expands so we used some scrap plastic, a straight edge, off cuts of green eboard and my Mapecem Pre-Mix bags to keep the drain still while the spray foam does it's thing.
