721 - 740 of 4,122 Posts
I dont know how much that small strip of Noble is going to work.
it might help a little but they require it to be a little wider.
ps. I thought you were a Laticrete guy. you can use HydroBarrier, Blue 92 Anti-Fracture Membrane or the Crack Suppression Kit ;)
actually its alot bigger than ya think knuckle head..............its 20 inches wide and the crack or seam was 1/2" and BTW I am using a PREMIUM thinset...............
what are you the tile police now:censored::laughing:
With Noble its 2 1/2 the size of the tile.
Dan you look like you are at just 1 tile diagonal, you needed to be 2 1/2 (diagonal) tile width.
but it's not my floor, just trying to help you out since you never seen a cut joint in a lanai slab :eek:nline2long:
Discussion starter · #735 · (Edited)
Yah might try that. Usually don't have good luck with the RotoZip but this is travertine.
The floor bit will cut through that like buttah. Amazon is the cheapest place to get 'em. Keep in mind the bit takes a 1/4" collet. They are a little slow, but it beats the heck outta payin' for an expensive hole saw you might need once in a blue moon. ;)
seeing how the homeowner is a engineer and that is what he wanted and he is writing the check for. I do belive I will do what the engineer wants. The house is 9 years old i am pretty sure its done moving by now. But if I get some hair gel and a white truck I can be the tile police. Now I dont go posting snotty remarks on your pictures I expect the same:whistling. Thats right you blocked me on facebook because I had to correct you so much:eek::thumbsup:
I thought you said this place is for tile hacks??? and now ya come over here alot. WOW FAN CLUB FAN CLUB............autographs at 9 pm with beer.............
Don't cry when someone points out how your doing something wrong.
It's fine when you yap and make outrageous stories and we all need to listen, but the other way around doesn't work for you I guess. :jester:
Learn to take criticism the right way.
Your membrane across that joint is still wrong no matter if the guy is a teacher, plumber, architect or astronaut.
You told me how to cut my plank tile rows and use tue waste and proper spaces with no H's. I listened, learned and do them all that way now.
