2,061 - 2,080 of 4,122 Posts
Heated floors are always a PITA, unless you're magical with SLC.
I thought I either tooled it too much or too little, or didn't mix it properly or something. At first I tried to float it out like concrete but it is so sticky and watery it has a mind of it's own. Then I just dumped it and used the back of a rake...then dam off the leaks from the water pipe I didn't spray foam. :laughing:
I had some hills and valleys that were about 1/8" off in the worst spots. If you look closely there are some spots where lippage occurred and I couldn't level it out by lash clip alone.
I couldn't believe how hard it was to peel up a tile once you lay it, I had to hammer a wedge underneath a few to break the suction then pick it up.
Still I'm fairly satisfied considering it was my first ever time cutting and laying a tile as well as my first batch of thin set I've ever mixed.
Looks good Inner10 !:thumbup:
Inner10 said:
I learned that setting tiles sucks, I ruined my pants and my fingers and knees are killing me.
I fail to mention those things and it seems Angus did also!
Thank you!
It is far from perfect though...I admit looking back the wonkyness of the floor was my demise. I should have marked all the high and low spots and started with the high spot and went out from there and keeping everything perfectly level.
The LASH system sure doesn't level anything (much like the instructions say). There are some places where the tiles are out of level just to avoid lippage...and some areas where there is slight lippage to compensate for a less than perfectly level floor.
Next time if I were to use the LASH clips I think I would mix the thinset a little thinner and use the bigger U notch trowel like Angus suggested instead of the 1/2x1/2. I found once the tile was dropped it was suctioned so strongly to the floor it was almost impossible to squish it down...and the 1/16" grout lines don't let any excess squirt out...so I did a lot of prying up the tiles and removing excess schmaltz with my margin trowel.
I took for granted how "self leveling" self leveling compound is...I also took for granted how much "workability" you have with thinset; you can't just muscle the tile into place.
I'l take some pictures of the errors when I get the mountain of dried thinset off the tops of them. :laughing:
Plus how do you guys keep your hands clean from mucking up the tiles? I had a grouting sponge, 5 rags and 2 buckets of water and I was constantly washing hands, switching rags, washing the sponge, wiping the edges of the tiles, cleaning the grount joints with a putty knife, wiping the tiles down (which didn't work around the LASH wedges) and still I made a massive mess.
I should add...my girlfriend gets home from work and looks at the tiles...then she gets her nose about 6" from one of the slightly high corners and picks at it with her finger and says "so how do we fix this?"
:censored:
We don't!
...I think I was expecting more of a "thank you" or "good job"...not in this fvcking house.:laughing:
Im at my wife's 30th HS reunion all weekend just south of you in Massena NY. I can be there in 1 hr to do a fix. Please ask me to do it...please?
Your right around the corner from Cornhole, enjoy your reunion! :laughing:
That sounds as fun as visiting the in-laws. :whistling
