Sunkist is correct about paint; if durability is the main priority then a well-maintained coat of paint is the best route. On the other hand your posts may last pretty well and you can just replace boards as they fail; that's fence maintenance.I used treated 4x6x8 posts instead of regular 4x4 cedar. We have had problems with the wind in my area and also with the posts rotting out at the ground so we went a little overkill.
I understand there is not a great way to preserve wood, as eventually, it will rott out. I just need a stain or sealant that will last longer than 1 year and possibly help a little.
Thanks,
Mandy
I have plenty of extra pickets. I'm hoping the posts last a while.Sunkist is correct about paint; if durability is the main priority then a well-maintained coat of paint is the best route. On the other hand your posts may last pretty well and you can just replace boards as they fail; that's fence maintenance.
The key statement there is well maintained. If not, paint is the worst choice, unless you don't mind flaking paint and prematurley rotted lumber.Sunkist is correct about paint; if durability is the main priority then a well-maintained coat of paint is the best route. On the other hand your posts may last pretty well and you can just replace boards as they fail; that's fence maintenance.
Yes, you must maintain a paint finish properly. And paint isn't what it used to be.The key statement there is well maintained. If not, paint is the worst choice, unless you don't mind flaking paint and prematurley rotted lumber.
