1 - 20 of 33 Posts
I own stock in FotoMat!
Will, PVC is PVC. Once you get to sizes larger than 1¼", it's usually cellular-core to save weight. But you're using it in an application it's not intended for, so there won't be any specs from the manufacturer about weight-bearing capacities. So it's try a few and hope the weight isn't too much.
I once moved a shed 8x12 100 yards down a street on 2” pvc waste pipe use 5 pipes and guy switching pipe could not keep up
regular pvc will work fine
Demo
Terrain matters. Keep in mind the small diameter stuff will bind on pebbles and stuff. Any skateboarders from the 90s will know what I mean.
Remodel
1 - 20 of 33 Posts
