1 - 20 of 48 Posts
Finishing Carpenter
I absolutely suck at drywall mudding LOL I put it on, sand it off- repeat. I'm getting better at it though, got some advise from a buddy who's a drywall mud guy. He's amazing at what he does, I think it's skill/art combined.
I am good at angles/crown moulding - not sure why. Working on a job now where I am joining a 41 deg. spring angle to a 32 deg. spring angle, while maintaining the reveal on the header that it rests against.
That means that one piece is 1" shorter than the other, so the pattern doesn't match. Solution: set it up in my garage, use a piece of kd spruce 2x8 and match it up to the 41 deg piece, trace the pattern then "slowly" push it through my table saw sideways (sorta) carving out hollows a bit at a time. Takes about 4 hours to do 2 feet LOL I've got two done, two more to go. Client is over the moon, two other crown guys said it couldn't be done :) and yes, I'm losing my shirt on this one hahahaha oh boy.
I also did a fence for a client recently, only because they are a good client - I don't do fences.
string line, plumb bob, laser-that fence is so g######d straight and plumb! this isn't the way to build a fence!!! but I don't really know another way and being a trim guy I just use what I know - so to the fence guys, you have a fan cause I've seen crews workin like bees digging/nailing - done! and it looks good.
So what are you good/notsogood at?
topsail's trimcat
good at
interior / exterior trim
decks
siding
framing
suck at
painting
taping drywall
broom finish in concrete
Reactions: Jaws
I suck at plumbing. I also hate it, so little chance of me doing it much. I am great at creative problem solving as it relates to my trade (framing) and as a crew, we are getting pretty good at exterior trim (Azek, cedar. etc.)
The Ultimate Wire Hider
So do I. But I get around it by adding several thin coats of mud to get it smooth. I could never understand why people go through that vicious cycle of spreading it on and sanding it down just to spread more on it.
Also, I suck at cutting straight lines with a circular saw. It doesn't matter if it's a 2x4 or a sheet of plywood. The cut comes out with an angle every time.
I'm relatively good at plumbing. I've never had a sweat joint break loose in the last 20 years.. but then again I use 3 to 4 inches of solder on every joint leaving all of those silver boogers on the floor. :no:
My roofing work is suspect. The only roof I ever installed doesn't leak but I am not 100% sure that I did the job properly.:whistling
Landscaping is not one of my stronger points either. Some people can move their trees and bushes around like it's furniture. Anything that I try to plant or replant usually dies. :rolleyes:
Love me some Concrete
Here's my problem:
I can build a house, wire it, plumb it and literally do all of it including foundation except for HVAC.
How the fvck can I not figure out how to bleed the brakes on my kids quad! I have no skills mechanically other than changing oil and I probably could screw that up!
Lazy Millennial
Carpenter
I'm good at finishing, fine details, and organization. I'm not great at framing. Sounds funny because I'm a carpenter but I think it's more do with exposure to it. I haven't had a chance to really work with a dedicated crew doing it.
I'm also bad at small talk. Someone asks what I do for fun and my mind goes blank. :laughing:
Sent from my Nexus 5 using Tapatalk
Builder
Same as kirk, add welding to the good at list.
I wont paint. Lol
Not good at any MEPs because you have to be licensed in Texas to do any of them. I have done very little of them myself.
I suck at getting up early. :laughing:
I had the benifit of watching and learning from a Master Plasterer,
He told me to pretend you are doing body work on a 57 chevy.
Put it on smooth and leave it.
If it doesn't go on smooth it is too thick.
I hate ceilings. :censored:
Hack
I'm good at formwork and landscape installation...getting better at trim and hardwood flooring.
I suck at concrete finishing (flatwork), and I will NOT paint.
sometimes I suprise myself at the things I have become good at, like drywall. I get done and my help is like damn this turned out nice, I think its all in tips from people better than you and pratice,also afew " Im broke and need to get this done times" :whistling
Administrator
Sawdust follows Me Everywhere
Good at almost everything.
Horrible at stone and brick work.
master hacker of wood
brhokel606 said:
Here's my problem:
Go too harbor freight, get the Blake bleed tool,
It hooks up to a compressor, and sucks the air and fluid out leaving no bubbles !!
Cheap too, you may never get it doing it the old way dude quads are the worse!!!!
Nail Driving Fool
Here's my problem:
I'm the same way. I can build practically anything. I can start with a sketch drawn on a McDonald's bag and a pile of lumber and turn it into something beautiful.
But if its got a motor on it, FORGET IT! :laughing:
1 - 20 of 48 Posts
