1 - 20 of 35 Posts
Replacing basement windows in cinder blocks.
This polyurethane based masonry caulk is amazing
http://www.homedepot.com/p/Loctite-...e-Crack-and-Masonry-Sealant-1618522/203156788
so I want to use this as the main sealant and then mortar over it for a nice finish.
Can I brush on a masonry bonder slurry to the cured poly caulk and then mortar (mixed with water plus more bonder) over it and not worry about the bonder/mortar eating away at the poly caulk?
http://www.homedepot.com/p/Loctite-PL-10-fl-oz-Polyurethane-Concrete-Crack-and-Masonry-Sealant-1618522/203156788
Shouldn't you ask the manufacture? Im sure there's an 800#. Not being sarcastic or anything. Just saying, that may be the best place for the most accurate info
If these are glass block windows, why don't you reverse the process you are suggesting.
Set the windows in mortar, leave the mortar shy of the face, caulk and blow sand into the "curing poly caulking" .
why do want mortar as a finish? caulk and walk...it rhymes so it must be true
That's how I've always done it, but caulk looks like sh*t as a finish against an existing mortar wash (or whatever you call the angled mortar outside the window that holds in it and keeps water running away). Especially the polyurethane based caulk since it's a lot globbier and harder to smooth to a finish unlike the basic DAP $3 masonry caulk.
The mortar will be applied over about %25 caulk, %25 plastic (the window frame) and the main %50 over the existing mortar, all with bonder slurry added first, and bonder in the water to mix the mortar, so even if mortar doesn't adhere to the caulk, it will to the existing mortar and should to the plastic window frame also, so I'm not worried about it crumbling since it's not as thick of a mortar application VS just mortaring the whole window in without caulking. I added the poly caulk because of it's flexibility from freezing and house settling etc, r value, air and water tight VS just mortar.
Love me some Concrete
I am a bit confused...
We have always replaced the windows, hammered and chipped all of the old mortar out, installed new window, foamed and after foam set, mortar winow inplace. We re-create the slope for water to run off and then in the next day or 2, apply clear caulk to mortar and window joint. Minimal caulk and can be completed quickly.
Have I been doing this wrong then?
no thats a good method. Install the mortar if you ahve to but you need to apply caulk between the mortar and the window
Did I miss something?
Did the OP say he was installing vinyl windows?
My mistake.
I did miss something. The OP's follow up post.
Set it with minimal expanding foam and some tapcons.
Use the "mortar poly" once the window is set.
"Float" in a sill after the window is set.
(something tells me, I'm still missing something...)
Discussion Starter · #12 · (Edited)
if I do as suggested i.e:
1. great stuff for windows/doors if gap is over about 3/4" after new window is put in. 2. mortar over that and then apply clear caulk where the mortar meets the window once mortar dries,, then what if the house settles or the mortar decides to crack (even with bonder added)? Great stuff (if even needed) isn't waterproof, it's only water resistant. Think of a window 6" off the ground with expanding ice on it for weeks. That's why I think to add sealant/caulk on top of the great stuff (once cured and trimmed) and mortar over everything to complete.
Unless wet mortar eats away at the caulk/sealant, the worst case scenario is that the mortar cracks and a new $3 bag of mortar is needed to repair. I can even go so far as to layer something over the caulk sealant to protect it from the wet mortar.
Caulk/sealant where the mortar meets the windows as the final step is a good suggestion though.
dommas, you contradicted yourself, you told me the mortar will crack as the vinyl and masonry expand but then you told 606 that mortaring is fine.
I've never set vinyl windows with mortar acting as exterior trim. I once set windows in a block foundation with stone veneer. I used aluminum capping around the window, with a nice, hemmed bend laying on a flat mortar line to meet the stone.
That was about 9 yrs ago and the job still looks great: no issues.
Glass block, yes.
A picture would help.
mortar is fine to fill the space between window frame and surrounding masonry but it WILL crack where it meets the vinyl (or wood or aluminum)...so after the mortar has cured caulk between the mortar and the window. I cut a small key into the joint so the caulk is more than just pasted on
anytime 2 dissimilar [products meet there needs to be an allowance for movement...a soft joint, mortar is the opposite of a soft joint
Discussion Starter · #17 · (Edited)
ok thanks, so how about instead of caulking where the mortar meets the vinyl after the mortar cures, why don't I put a layer of caulk over the face of the vinyl where mortar will be, let that cure, and then mortar over it so that there's no place mortar touches vinyl. All mortar will meet flexible caulk as illustrated:
do this:
not this:
Vinyl on the window is so slick mortar will not stick. I have splashed mortar on a window without knowing it, came back next day and you can just brush it off. After I mortar, I wait the day or 2 so it dries but the bond also breaks so the window can flex. I do not screw the window in, I foam it in, for those of you that have tried to remove foamed in doors and windows know exactly how it holds.
I had 2 of my guys spend 4 hrs trying to remove a sliding glass door that was only foamed in, it kicked their butts!
There is no mortar around the window, only foam. The mortar then covers the cut flat foam to seal it. Then caulk after mortar is dry
Discussion Starter · #19 ·
You build the second image I posted above but using expanding foam instead of polyurethane sealant. I know great stuff isn't waterproof and is only water-resistant, but maybe you found waterproof foam? I know windows have been set in mortar since like the 1200's or something, but aren't you worried about not having a better sealant like polyurethane caulk or at least non-polyurethane masonry sealant in case the mortar cracks from ice build up (if you live where it's cold)? I'm talking about the main portion of mortar, not just cracking the seam where it meets the vinyl that you say you caulk to allow expansion/contraction.
The windows are already installed and caulked in like the first image 'do this:' minus the mortar yet. I'm waiting back from loctite if their polyurethane masonry sealant will be affected by wet mortar, it probably won't, but if so, it's probably easiest to just caulk over polyurethane caulk with cheaper DAP non-polyurethane sealant:
http://www.homedepot.com/p/DAP-10-1-oz-Watertight-Concrete-Filler-and-Sealant-18096/204167828
because unlike the rubbery polyurethane-based sealant, this can easily be troweled smooth then dusted with mortar to look like mortar. Caulk and walk looks ghetto, I want a nice finish, trim is an option, but kind of tacky and I don't really want to custom cut all the angles and stuff.
Thanks for the suggestions.
1 - 20 of 35 Posts
