I am selling my Werkmaster Titan. Here is a copy/paste of the ebay listing. Contact me at [email protected] with any questions.
$13,000.00
Werkmaster Titan
Concrete Grinder/ Polisher
Used Werkmaster Titan for sale
This machine works great for concrete grinding and polishing
I am upgrading equipment and need something larger. Perfect to start with in concrete prep or polishing
Includes tooling, consumables and repair equipment to start right away. Just add a dust extractor and start polishing
Operate on single phase 208 or three phase
Great machine, very easy to work
WerkMaster™ Titan™, 10 HP, 208/250 V, 450-2100 RPM, 5-3/4" Disc Size
WerkMaster Titan™ expels the myth that bigger and heavier is better. The Titan provides amazing power and speed. Fantastic for surface preparation, grinding and polishing. Ideal for projects 5000 square foot and under.
Features
• 7 Machines in 1 - grinder, polisher, edger, sander, buffer, burnisher and stripper
• Edging to within 1/8" (3mm) of the wall
• Patented Octi-Disc™ Technology
• Patent Pending ULTRA-FLEX Plug'N Go™ System - Allows you to both follow or flatten a floor
• Auto sensing dual phase Variable Frequency Drive (230V model only)
• Prep to polish on virtually any solid surface flooring
• Adjustable Handle
• Dual action Vacuum port, for dry, dust-free pick up
• Wet or dry grinding
This machine, tooling and equipment is sold as is, where is. If you have any questions ask before bidding. If you want more pics, ask before bidding. Don't bid if you can't afford. I am still using this equipment. Some diamonds will see more use. Once I get a deposit I will stop using it. Buyer responsible for shipping. I will put on a pallet and strap down. You will need to co-ordinate shipping.
Tooling and Equipment Included- Values Posted are for new, all tooling is used unless noted
24- 100g Pro Resins @ 19.95 ea $498.75
24- 200g Pro Resins @ 19.95 ea $489.75
26- 400g Standard Resins @ $5.95 ea $154.70
29- 800g Std Resins @ $5.95 ea $154.70
23- 80g Metal Bond X Soft @$24.95ea $573.85
33- 50g Metal Bond Super Seg @ $45.15- $1489.95
13- 50g Metal Bond- Emergency Worn Out Segs
4- 25g Metal Bond- Emergency Worn Out Segs
4- 20g Pakman Double seg- Emergency Worn Out
8- 20g Pakman Double Segments- New never used @ $51.45- $411.60
20- 30g Hybrid Resins @ $19.95- $399.00
24- 50g Hybrid Resins @ $19.95- $478.80
24- 100g Std Resins @ $5.95- $142.80
8- #1 Applied Diamond 6" Resin Pads (50-100g) @ $35.00- $280.00
8- #2 Applied Diamond 6" Resin Pads (100-200g) @ $35.00- $280.00
8- #3 Applied Diamond 6" Resin Pads (200-400g) @ $35.00- $280.00
8- #4 Applied Diamond 6" Resin Pads (400-800g) @ $35.00- $280.00
8- Velcro Back Ultra Flex Adapter Plates @ $68.25- $546.00
8- Plug N Go Plates @ $103.95- $831.60
4- New Velcro Backers for Ultra Flex Plates @ 12.00- $48.00
2- New Extra Plug N Go Plates @ $103.95- $207.90
8- Suspension Foams @ $9.50- $76.00
6- Shear Pins @ $11.55- $69.00
2- Main Drive Belts @ $50.00- $100.00
20 Black Grommets- $20.00
1- New Pad Driver- $74.95
Over $4700 in Diamond Tooling
Over $1900 in Extra Equipment
Buyer Responsible for Shipping
$500 Paypal Deposit at end of Auction
Balance Due by Cashiers Check/ Money Order
Item may be picked up when cashiers check clears
Item sold as is- no returns, no refunds
Ask questions before bidding
Item is for sale locally- reserve the right to end this listing at any time
Email with questions- [email protected]
$13,000.00
Werkmaster Titan
Features
• Adjustable Handle
