Does it matter how they are wired. I'm used to seeing black black, white white. I mean it works and I wired it back that way. Just curious.
That was the before photo. I changed the tank and all the other parts.rselectric1 said:Looks right to me. One side is the line side, and the other is the load side that is connected when it needs power. Rex, you even put the wires on in the right direction under the screws!:clap:
Not sure what voltage it is.jamesgr81 said:Is this 120 volts or 220 volts? You can see that the contacts bridge the the two left terminals together and the two right terminals together. Line1-load1 - Line2-load2 If 120 volts it will work but code-wise wrong. Should be black - black and white-white. If 220 volts no problem. But I would still connect it as black-black and white-white.
