1 - 11 of 11 Posts
So talking to a homeowner today they show me this. It's a drilled hold in conduit that water drains/ pisses out of.
How do you find the leak? 10 year old home, builder or sparky did this and the electric company says it's common. What happens when the hold doesn't allow enough water out and it enters the meter ? Fire hazard? Electric shock hazard?
This isn't part of my job but it seems really not right.
hack of all trades
If you need a weep hole in your conduit you obviously did something wrong. I re ran an emt line for an espresso machine once and when I pulled apart the original conduit it was full of black muck and water. That guy forgot the drain hole! Nec article 344.? RMC drain holes: coming soon
hack of all trades
I've never seen a drain fitting installed, but I'm also pretty green to building trades and I've never worked in any industrial settings. I'd be interested to see a situation when drain fitting is required/recommended. Haven't come across any code reference to it that I can remember, but, again, I haven't been reading NEC for long.
Completely serious?
yes
http://ecmweb.com/content/conduit-fitting-guide
Drains. If your installation is in an area of widely varying temperatures — or if conduit runs from a warm area to a cool one — you can expect condensation. Install a drain at the lowest point of the run and at any point where water might accumulate. If the conduit runs underground (or to any place where a drain isn't feasible), create a low point ahead of the entry and place a drain there.
1 - 11 of 11 Posts
