1 - 20 of 93 Posts
Let me start by saying I know I effed this whole thing up and I am also aware that I am asking a lot. So many thanks in advance for ANY advice.
Quick rundown.
Bought house (6+ years ago), water tested positive E. Coli. during inspection, forced a UV install pre-sale.
Had 10 month old when I moved in.
Crushed 6 mo. reno in 2 mos. Barely made it for move-in (wife back to work/nanny install)
Knew (know) little to nothing about water filtration/treatment (nyc, turn spigot and go)
Took existing system (???) and added way too many filters etc. (new Dad, overblown protective instinct)
My well tested at 30-35 gpm at inspection. I replaced the pressure tank w/ same size, added 2 whole house filters, plus the UV, and stretched out the existing system.
My pressure has always sucked and I am finally tired of it and ready to fix it.
Right now I have it jacked up to like 80-90psi out of the tank( and it still sucks), doesn't seem like a great long term plan.
I have tried researching what my best course of action would be, but I have a lot of chit going on down there and am getting a little confused.
System as it exists:
Submersible to
pressure tank to
fiber whole house filter to
chlorine injection to
(2) holding tanks to
AC whole house filter to
(2) smaller AC filter units to
water softener to
UV light...............................to (3) (yes 3) hot water heaters and a vicious maze of apparently HO installed pipe.
Too many tees bends and elbows, too many filters. Rip it all out after the pressure tank, install one filter, one water softener, and one water heater. Chlorine is bad for you anyways....
80-90 from the pressure tank and you can't tell it= major restrictions in the water flow.
Reactions: BlueRidgeGreen
Did you adjust the bladder in the tank, or only the pressure switch? Is the switch actually working correctly. Do you have a hole in the line coming from the well?
Yea, I checked all that. Everything from the well is cool.
The chlorine injection was existing, so I figured (knowing nothing AT ALL) that I needed it for the iron. Then I read about the carcinogenic byproducts and how AC filters removed them........so I installed a few of them:whistling.
I'm just losing so much pressure going through all those units and probably because of the maze.
I guess now I have to figure out if the chlorine is really necessary, because if I can get rid of that, i can get rid of the "save me from cancer" filters, kill the superfluous heaters, and streamline the pipes.
Thanks for responding to the Death Valley of threads. Much appreciated.
Remodel
Personally, I'd keep the chlorine treatment. Here's why:
You had some E. Coli problems. That probably means your well is too close to a septic system or too shallow or both. While you may decide to not use the chlorine system routinely, it gives you the ability to decontaminate your water system if you need to. You use very high levels of chlorine when you do this, and don't use the water, typically.
Pex will give lower pressure drops, and since you can use gradual bends instead of elbows, you'll lose about 5 feet of equivalent piping for every elbow you get rid of.
Chances are the filters are the big problem - they look pretty small.
Ink Slinger
In this area, regular bacteria is handled with uv light. Fecal coli. Get the chlorine treatment.
Discussion Starter · #9 ·
My septic is an older homemade concrete tank 16" from my foundation and approx 60 feet from my well, which is only 80' deep. My field is at least 50 years old and in need of replacement, but considering how codes have changed, it's going to cost a fortune. I flushed and cleared it by hand and am waiting to figure out (and afford) a solution.
The well is only 10' from my house and my property is surrounded by creeks, streams, and technically and literally in a flood plain.
I had just considered killing the chlorine but now I'm thinking twice.
When I flush the holding/retention tanks (very rarely, once a year...if that), I see no evidence of iron sediment. It seems as if the first whole house sediment filter is catching most or all of it. I change it every three months and it is pretty loaded with iron.
Won't the UV take care of any bacterial problems?
With (2) whole house and (2) smaller filters, I am definitely overfiltered, right????
Also, I often fill and leave 5 gal. buckets from my outside hose, which is pre-filtration and notice no signs of iron.
I'm just going to get a good water test done and go from there.
I'm going to give figuring it out on my own a good effort before I call in some favors.
Can't thank you guys enough for the help. I know some would prefer I just call in the big guns and write a check. I could. But I find I learn much more about the things I am responsible for if I fight it out a bit.
Thanks for the backup:thumbsup:
Discussion Starter · #11 ·
I can help you figure it out but it's going to require a lot of questions. Are you up to the task?
Truth be told, I actually posted the thread during a period of heavy Oco-activity in the hopes that you might chuck a tidbit or two my way.
I am definitely up to the task and really looking forward to it.
Just tell me what serial number you need, where to dig, what to smash to bits, and I'm on it.
Sure. We'll pick up this conversation tomorrow alright?
Discussion Starter · #14 ·
2 story (1/2 basement)----------- (14) Total Fixtures
Basement level/Ext Wall (1)
- (1) Hose Bibb
First Floor (6)
Kitchen
- (1) Sink
- (1) Dishwasher
- (1) Refrigerator
Powder Room
- (1) Sink
- (1) Toilet
Laundry Room
- (1) Washer
Second Floor (7)
Hall Bath
- (1) Sink
- (1) Toilet
- (1) Tub/Shower
Master Bathroom
- (2) Sinks
- (1) Toilet
- (1) Shower
I'm sure that I'd just do what Oco suggests, what with him being the expert and all. But on my own house, first, and out of plain curiosity, I'd shove some tees and ball valves in along the way and see if there was any one place that the pressure or volume was going away, probably removing filter media to see the effect. A few bucks and a few minutes per valve. Just curiosity.
Regarding the question: Won't the UV take care of any bacterial problems? UV and ozone kill what's there, but the organic matter remains; it's just dead now, waiting for a chance live organism to find it and breed. Therefore the filters.
1 - 20 of 93 Posts
