water drainage issues
2263 Views 7 Replies 8 Participants Last post by  jmacd
long time reader first time poster i see you guys now a lot about site and earthwork im hoping you can help me out im new to the digging world so dont beat me up too hard i have major drainage issyes where my rainwater is quickly running down hill and washing away my excavation at my site making it difficult to keep a smooth consistent slope i heard from a guy near me that i need to train the water to run uphill but i cant find anything or any info on how to do this have any of you tried to do this before if so how long does it take and do i have the right equipment the hilside is 650ft long and has a constant slope that is approx 65ft lower on the other end then it goes up a slight slope about 10ft long approx 2ft higher than the lowest spot im using a bobcat and kubota kx41-3v excavator thanks for the help
1 - 8 of 8 Posts
It does not sound all that steep, 1' drop in 10'. What exactly are you trying to accomplish? Establishing a lawn? More info please.
When doing detention basins or cuts where I will have water runoff coming down on my slopes, I will create slight diversion ditches. For example, I'll cut a small ditch in along the top of the slope of a detention basin and then I'll run it all the way to the corner of the basin and then I'll curve it in and I'll rip rap the corner down to the bottom to prevent any erosion.
More info is needed, is this slope covered or bare dirt, etc.
Does this site work have a NPDES permit, it sounds like it is large enough to require one.
.....i heard from a guy near me that i need to train the water to run uphill but i cant find anything or any info on how to do this...do i have the right equipment?
You need a low ground pressure embankment grade inverter with a 5-way blade and gps traveler to do the grading you're describing. Use a high volume hydraulic driven sod blower to get it stabilized quickly. Your local Cat dealer can probably rent both to you.
Reactions: 3
you never cease to amaze me
li heard from a guy near me that i need to train the water to run uphill but i cant find anything or any info on how to do this have any of you tried to do this before if so how long does it take and do i have the right equipment
I've met a few Engineers that think they know how to do this.
I have seen this method used before, just amazing how they do it!
1 - 8 of 8 Posts
