Free Specs Online!
The material for the block walls will be different than what you can use on a sloped floor. Block walls will need a special non-slumping 2-part epoxy paint that is the right viscosity to fill substrate pores and divets, but will also stay where you put it on a vertical surface. As to the floor, in assuming you have no moisture barrier underneath the slab, there's concern about a thinner product "blowing off" from moisture vapor pressure coming up from underneath the slab. A urethane concrete mortar may be your best bet. Take special care to spec proper coving around the floor-wall joints, as well as around the drain. Good luck!
See less
