wall mounted shower seat
2340 Views 5 Replies 4 Participants Last post by  CO762
Is it possible to use a wall mounted shower seat with metal stud wall? I want to use WEDI, too.
1 - 6 of 6 Posts
Sheet the walls with 3/4 fire rated plywood prior to wedi install and you're good to go.
Long channel that locks through the small bottom rectangle of the punch out.
Helps unitize the wall.
Depends upon how you mount the seat. And what type of seat it is.
Depends upon what type of seat are you using and where/how does it terminate.
1 - 6 of 6 Posts
