1 - 6 of 6 Posts
I'm meeting with my electrician later in the week on this, but am curious now.
Home inspection says that the motor of a walk-in tub (as seen on tv) appears to be protected by an Arc fault breaker. They want Fit GFCI protected.
Would that be simply done by adding a GCI prior to the motor, or do I need a feed from a non-AFCI protected circuit?
Thanks.
If I recall all those jetted tubs etc need to have a GFI and the last one I installed had its own 10ft grounding rod per code.
I own stock in FotoMat!
10ft? Seems kind of long yes if there is a ground fault you want it to get to ground fast!
And ground rods are NOT for that purpose. Ground rods are TERRIBLE for clearing faults. So terrible, they're not allowed to be used as such.
Electrical Contractor
Sounds like the unit is 120v so it would need gfci but afci is not required in a bathroom. I assume that is where it is being installed.
1 - 6 of 6 Posts
