Voltage Drop in Home Inspection?
8135 Views 3 Replies 4 Participants Last post by  Apizur
Does anyone here know what type of load is applied to a 15 amp bedroom outlet circuit when being tested by a home inspector? Also what would acceptable v drop be under that load?
1 - 4 of 4 Posts
There is no load placed on the circuit. Each outlet is checked for polarity and proper grounding. Also voltage does not change on a parallel circuit when a
Resistance is applied to it.
If your showing a voltage drop check for loose connections first
This.
1 - 4 of 4 Posts
