Vinyl Plank Flooring Transitions from Room to Room w/ Same Flooring
24K views 27 replies 15 participants last post by  AlaynaStanley
Remodeling contractor (new) here and hoping for some feedback. I want to do this right and I am hoping for some advice. Attached is the general layout of the first floor of a home. Planks will be be laid from bottom to top in accordance to my drawing. My customer would like vinyl plank flooring throughout the first level (same flooring). I've seen floating floors laid down w/out transition strips from room to room. The LifeProof brand instructions only mention the transition requirements for runs more than 100 linear feet.
Do I need transition strips? If so, what is your opinion on the location of them?
Secondly, if I DO NOT need them are there any tips you can offer me to get everything line up correctly when wrapping around the hallways to the kitchen or living room?
Thank you
#6 ·
I avoid transition strips whenever possible. You shouldn't need any there.
I've had good results using LIfeproof. While its drop lock ends may be a tad less bulletproof than driven ends, they make installation much easier. And it's thicker than many other brands, which helps bridge minor irregularities in subflooring. All brands have their pros and cons; none of them are great.
Tip that can save you grief: Forget about using those crappy plastic shims to get your 1/4" spacing from the wall. They always move in one way or another.
Instead, start your flooring with the second row from the wall. Where the first row will be, screw scraps down to the subfloor to drive everything against. When you're done with the rest of the room(s), remove the scraps and install that first row in their place.
#9 ·
I just tried that on the last floor I did. Works awesome.
#8 ·
No need for transition strips.
Against most advice so far, I would start in the corner of the two areas marked hallways and work my way out into the largest room.
#16 ·
I would also work off the long wall. You can lay a 1x anything along the long living room wall and start clicking. It's self squaring so after a couple of feet will in you can see. Then remove the 1x and slide it back in place put shims where needed.
It's way easier to run through the same direction but that little perpendicular hallway would bother me. It should change direction and miter on the back connection off the kitchen.
#28 · (Edited)
Vinyl plank flooring is a fantastic choice. Regarding transition strips, it largely depends on the layout. If you're dealing with shorter runs and no significant transitions, you might be able to skip them. When navigating hallways, ensure proper alignment by taking your time during the installation, using spacers, and double-checking measurements. Vinyl flooring is forgiving, so you have some flexibility. Good luck with your project, and here's to a seamless and stunning first floor!
This post has been deleted
