1 - 12 of 12 Posts
Joe The Handyman
I went to double check my measurements for a storm door replacement and realized that the vinyl J channel was installed over the storm door flange.
Any suggestion on how to swap out this door?
Unzip the siding and remove the j channel.
Install new door.
Reinstall J and siding.
or
Box out for the storm door so the j doesn't cover the flange which will require cutting back each piece of siding. either way, siding is probably coming off to do this correctly.
Get a "Hooker" or 'Stripper' and unzip the siding, pull the J - do the storm door.... reinstall the J and zip it all back up
Pretty much the only right way to do it. Why do people do things like that , don't they think the storm will ever need replacing.:rolleyes:
Beyond that, 10 bucks says, the J wall rolled on the flange anyway :blink:
topsail's trimcat
texas,, dont call it a hooker or rex will show up in this thread
Butcher of wood and metal
Personally if I was doing this the siding would get pulled back , brick mold put on then channel and cut siding to fit right so would not ever have this problem again.
Head Light Bulb Changer
You might be able to pop the channel back enough to get to the screws, but I doubt it. Either disassemble the siding or run a skilsaw around it and add new J (And lots of silicone - Hack job 101)
NOPE! It ought to last as long as the siding. That's what the salesman told them :laughing:
Or do you mean the siding should last as long as the door. :laughing:
I know the job is probably done already, but I had one like this a while back. I caught a break though and was able to leave the existing z-bar and hinges on the jamb. Weatherstrip looked good, no metal streaks on hinge and client was OK with doing it that OK .
Maybe not the best, but an option.
Andy
1 - 12 of 12 Posts
