My name isn't Vinny, and I am just a ditch digger, but my calculator says you're going to need right at 481Tons of asphalt to do the job.
Around here asphalt goes down for right at $90/ton plus mobilization etc. which would put the job at $44,000 or so. Factor in the difference in asphalt price where you are, etc. and that sounds like they are in the ballpark no problem.
Asphalt at the plant here is $48/ton, so they are getting about $42/ton to haul it, and lay it here in my area. This is assuming the plant is close, else hauling charges will be higher.
I am curious to see what Vinny says.:thumbsup:
