here in Sweden it gets more popular with glue .since you only screw maximum 10 screws / sheet i gets quicker and they ( manufactuer) say that you save screw cost
anybody ever stop to think that the glue only holds the back peice of paper to the stud, and does really nothing for the rock??:whistling
may be just me, but I don't glue at all :thumbsup:
Sooooo true!!!, Soft, not so bad, but after a couple of weeks... no fun. We like the rattling stud trick too. Wait, that just doesn't sound right. Rattling Stud and Sons, lol:laughing::laughing:Do a test sheet when you have some spare time.
Hang a board on the wall using a good line of glue on each stud. Nail or scew the edges, then hit the board over each stud and put 1 screw in any stud that rattles.
Let the glue cure a few days, then go back and try to pull the board off the studs.
Good luck!:thumbsup:
I've been at this madness since 1974, and I believe the reason people like glue is because they hate to spot screws. I personally refuse to glue, ever read the disclaimers on the tube?? If you know how to hang, the screws will hold it fine, however, if your using a dewalt screwgun, you may to glue, sho nuff.:w00t:True, the glue only holds the back of the rock in place, but does so over a large area. With the low pull out strength of gypsum board the screw is only holding a small area also.
We use adhesive with a minimal amount of screws.
They come out of adjustment and drive the screw in too deep.Why the hate on DeWalt guns?
.If you know how to hang, the screws will hold it fine
No disrespect Captain but I've been gluing and screwing drywall since 1971 and if you ever had to tear off a glued and screwed ceiling or wall , you would NEVER use just screws again. The best results are achieved by gluing approximately 40-42" of each sheet.On ceilings we put two field screws in every joist/truss.On walls we put one field screw in every stud.Around here (Illinois), it is Miracle Glue, and it exceeds it,s claims.Try it ,you will get glue on you occasionally but everyone will love the results.I've been at this madness since 1974, and I believe the reason people like glue is because they hate to spot screws. I personally refuse to glue, ever read the disclaimers on the tube?? If you know how to hang, the screws will hold it fine, however, if your using a dewalt screwgun, you may to glue, sho nuff.:w00t:
