1 - 1 of 15 Posts
A quick spin of the Ductulator says bad things will happen with the 4-inch duct.
I’ve installed the Fantech remote fans using 6-inch insulated flex duct in runs before of about 20-feet or so without issue. The higher CFM fans generally have the velocity to move air fast enough to prevent condensation accumulation in the duct work. Don’t forget to install a back draft damper.
A few feet of flex duct connected between the remote fan and the inlet grille also helps keep the noise and vibration down.
1 - 1 of 15 Posts
