Doesn't that need a Main Breaker inside the panel?Do you mean like this? To me this is upside down but I don't know if this ever passed inspection. Not sure if there is an issue here or not.
Not if there's a properly-sized breaker protecting the cable feeding it.Doesn't that need a Main Breaker inside the panel?
It was my understanding if it took more than six movements to turn off everything in the panel, it would need a main breaker.Not if there's a properly-sized breaker protecting the cable feeding it.
What I don't see, but I assume is there, is a grounding conductor and ground bar.
That only applies to the main service. If there is a breaker feeding the cable for this panel elsewhere, it is then a subpanel and does not require a main.It was my understanding if it took more than six movements to turn off everything in the panel, it would need a main breaker.
Numbers are not required. You can use whatever scheme you desire. Letters, Alphanumric, Binary codes..... whatever trips your trigger. The panel only needs to be labeled to show the load served. 408.4One practicle problem I can think of when load centers get flipped upside down is some brands (GE for sure) have circuit numbers stamped into the cover steel. So you get to look at upside down numbers. No big deal in my book, but probably some code guru somewhere wouldn't allow it. Crouse Hinds BR panels are no problem at all when flipped over, but for me they have lost all my business due to combo ark fault breakers that trip out for zero reason.
I recommend braille :thumbup:Numbers are not required. You can use whatever scheme you desire. Letters, Alphanumric, Binary codes..... whatever trips your trigger. The panel only needs to be labeled to show the load served. 408.4
240.81.i just got turned down for that a few months ago. First time ever tried and i got geeked. Breaker has to be on in up position. Somewhere in code. I think it's for firefighters mainly. Is there a code guru on here that knows where it is?
