jb4211:
I get this call all the time. I've remounted at least 25 sinks if I've done one. Without question, the best product is the Hercules Universal Sink Harness.
Remove the sink and scrape/abrade the caulk off the sink flange. Progressively finer grits will make it look like new. If you want to make this a one-man job, after mounting the wires to the cabinets, place (2) 2x4's across the sink opening, run a bar clamp through them and through the sink drain holes, and pull it snug. Check the wire length and when you're happy, lower the sink, apply silicone to the flange, tighten, and spray the squeeze-out with Windex and wipe up the globs with a paper towel. Check your reveals. Tighten the HUSH, remove the clamps and you're done.
I thought this was the most stupid and hillbilly invention I'd ever seen, then I used one:
http://www.braxton-bragg.com/HerculesSinkHarness/
These work great, but cost seven times as much and don't turn your sink into a 10" deep steel truss:
http://cinclips.com
All undermount sinks must be mechanically fastened, no exceptions. Silicone caulk between the flange and deck bottom functions as a gasket only.
