Uncoupling Membrane?
624 views 14 replies 7 participants last post by  nickko
I'm doing two bathroom floors for a customer. We are demoing the existing tile floors and the underlayment is 3/4" plywood with Durock adhered to it with thinset. The existing tile remained in good shape for 20 years. My plan was to grind the thin set off of the plywood and thin set new Durock over that then install my tile. Is it advisable to put an uncoupling membrane on top of the Durock?
Thanks
#3 ·
Durock just adds weight to the floor assembly, adding to deflection. There are much better and lighter substrates available such as Ditra which is waterproof and acts as an uncoupling membrane. Plus it's dust free and one person can carry enough to cover over 300sf in one trip. Add kerdi band over the seams and you can have a fully waterproof install.
#6 ·
As nicko mentioned, add the thicknesses you need to get the finished floor on plane with the other floors.
There is both Ditra, Ditra XL, Ditra heat, 1/8, 5/16, 1/4 respectively. You can use the heat membrane without the heat cable.
Remember the mortar thickness properly collapsed is 1/2 the trowel notch height.
Tom
#8 · (Edited)
If your subfloor is 3/4" as you indicated, then as long as your joist span and spacing meets minimum deflection requirements you are good to put Ditra on the existing subfloor. And as Tom said, use the approriate thickness Ditra for your new install to meet adjacent flooring. Between the Ditra and Ditra XL, you should be able to meet most adjacent flooring.
#9 ·
If your subfloor is 3/4" as you indicated, then as long as your joist span and spacing meets minimum deflection requirements you are good to put Ditra on the existing subfloor. And as Tom said, use the appropriate thickness Ditra for your new install to meet adjacent flooring. Between the Ditra and Ditra XL, you should be able to meet most adjacent flooring.
I believe the floor joists are 16" OC which appears to be what Schluter recommends. In terms of adjacent flooring, It's carpet on top of a pad on the same 3/4 plywood. I think the height of the thin set/ditra/thin set/tile will be fine where it meets the carpet and pad.
Back to the demolition ... the existing plywood had Durock adhered with thin set. My plan is to grind the thin set off. That will probably leave the plywood a little rough, bumpy and gouged. Will the thin set and Ditra be enough to bridge that rough surface? Or do I need to lay another layer of plywood to get a nice smooth surface?
Thanks
#10 ·
You’ll have to look at this as a whole.
Deflection is what matters, not 16” on center. The sub floor will deflect between the joists.
Make sure you use great duct extraction when grinding. I can’t recommend the Festool RENOFIX enough.
After you’re done removing the mortar you may need to do nothing to the sub floor, just use floor patch in a few areas, a layer of SLC, a layer of underlayment, then the membrane and tile.
A little rough is not a bad thing.
Tom
#12 ·
Tom
Tom can you recommend specific products for the floor patch, self leveling compound and the underlayment?
Is the demo started? Might find enough water damage to extract the original subfloor. (Likely not but anything’s possible) never mind just read the post. But still, might be easier to get down to the framing anyway. Little in from the walls with some solid blocking to lock in a 6” edge nailing.
Yes the demo is started and the Durock is making us fight for every inch we get off. So far we have not found any water damage. However we will be moving the shower drain so I will have to patch the old drain opening. That old opening will be beneath the new shower floor. I am using a Kerdi shower tray. The framing is open from the basement below. I was going to add nailers and patch the old opening with plywood then do my new shower floor on top of that.
#15 ·
I used a grinder on a kitchen floor a few times after removing cement board. I used a grinder dust shield hooked to a shop vac and had very little to almost no dust. If I was doing your job I probably get the worst of the thinset off with a grinder and cup wheel then use quarter or three eights plywood glued and screwed to the subfloor then just standard Ditra.
