My building is 32' x 24'. When I'm framing the walls, assuming my plates are 16' on the 32' walls and 12' on the 24' walls, what's the best way to tie them together? Should I have an end stud on both ends of both wall sections, or should I stand them up and then connect them with my second top plate? I've seen folks using ratchet straps to hold the two walls together while they connect them, etc, but I'm just not sure what's best.
Thanks in advance.
DWM
Thanks in advance.
DWM
