http://www.cttgroup.com/cantech/en/details/135/What is tuck tape?
Is it the same as duct tape?
Andy.
Stop shopping at Home Depot Chris, I get it for 6.50 last I checked, Venture brand.How do you mean use as vapour barrier?
We overlap vapour barrier and use it to seal the joints, use to to seal around penetrations in the vapour barrier. We also have the option to use acoustical sealant. I remember my 1 year in Saskatchewan the code/inspectors required both.
How would you use expensive rolls of Tuck Tape as a VB all by itself? Cost here is about $10 roll
That's bull****.I just had an inspector fail the VB in a basement development because we used tuck tape to repair the holes we made in the poly, as well as seal the little boots for the receptacles.
He said tuck tape does not count as a VB. We had to use acoustiseal.
It's never been a problem before.
Last time my guys went to buy a case at HD last year the cashier ripped open the box and scanned one roll - a whole case for $10Inner10 said:Stop shopping at Home Depot Chris, I get it for 6.50 last I checked, Venture brand. One inspector wouldn't allow a floating seam to be made with acoustic sealant, those had to be taped. Another job the inspector said it was fine to use exterior grade plywood and tape the seams as a vapour barrier. :laughing:
Bought a case of tapes once, scanned one.Chris Johnson said:Last time my guys went to buy a case at HD last year the cashier ripped open the box and scanned one roll - a whole case for $10 Thank you very much
I hope you corrected the mistake... :blink:Last time my guys went to buy a case at HD last year the cashier ripped open the box and scanned one roll - a whole case for $10
Thank you very much
I read in a book once about energy tight building that it isn't a bunch of small holes that will cause energy loss in VB, it's one small missing spot, could be just a couple square inches, or one missed seam (or one missed electrical box). Can't remember why now but it made sense when they explained itAcoustiseal doesn't work well on rec boxes because you need backing to create pressure behind the drywall. I usually use both to get just in case the inspector is being anal. By the time you put a bunch of drywall screws (with a few studs missed) then the cabinet guys drill a bunch of holes looking for studs ,I don't think the tuck tape will be what causes the problem, if there is one.
