1 - 18 of 18 Posts
Am I the only one who thinks this is a waste? I have a set of plans with a roof covered porch calling for treated ceiling joists and beams.
These architects are getting lazyier too. PDF details with conflicting info all over the place. Then I have a 3 1/2" x 11 7/8" treat lam beam for a 8ft
porch shed roof? Really? no second floor and half of that porch rafter is on the existing. Maybe Im just cranky because its 34 ft and about 12lbs per ft.
Seems a bit much considering I see those built with single 2x4 "beams" all the time around here. One house I looked at had a single 20 foot spanning "beam" laid flat and it survived through a heavy snowfall winter. It bent a bit. :laughing:
You should be more than fine. :laughing:
You know they used to have to think more when you draw something. CAD takes away from thought . I have here a Page of details where clearly the guy copied PDFs of previous work. Which I can understand but ledger bolts are being specified differently on the same Page in different areas. Same with footings.
If your joists are going to get wet you have bigger problems then what material the joists are made from. This Archy has a degree and is suppose to be the expert in this? Unbelievable!
KemoSabe
I have no problem with treated porch beams. I've seen way too many decks supported by mush because the beam wraps trap moisture due to faulty installation. Cheap insurance in my book.
Discussion Starter · #13 ·
I could be okay with the beam being treated it was the size that irrated me and that he called for treated ceiling joist.... Just not needed over the top stuff.
I don't I have ever built anything that was supplied from an arch I didn't know. I always modify to be win win. If the inspector questions I show them what I was dealing with and it's 50/50 if the plans have to get amended. we spec our own build and then verified with an archi / engineer combo. It makes me scratch my head with how they over complicate builds anymore. They you bid as planned and your too high. Chuck in truck comes along and looses his azz walks off 1/2 way through I get call back year later.... I guess I'm a lil cranky right about now.
what the ledger, roof etc? are you painting or leaving the pt? is this low budget low frills or banging like attached. :thumbsup:
1 - 18 of 18 Posts
