1 - 20 of 140 Posts
I know this has been Hammered here again and again. But I have to ask before I buy it. First I do not build custom cabinets. But I do knock down a lot of plywood for Closet work. Do trim a lot of doors.I am also trying to leave my table saw at home if I can.Second I am considering the Dewalt for price and Festool for other options.Does a Track Saw really get used a lot if you own one.Or is it a hassle to set up if I am only cutting One sheet. It is a lot of Money if I am not going to use it. Thanks Tony
There really is no set up. You set the track down on your marks, pull the saw trigger and cut. I mainly do framing and exterior trim. I bought one last year and have used it dozens of times. Until you actually use one, you don't think you need one. Once you buy one, you will always own one. I have the Festool (bought used) and started with a 55" track. I recently bought a 118" track but haven't used it yet.
Easier to transport, carry and set up than a table saw.
I gave up on running sheets through a portable table saw long ago. I will say, I would like to see a video of someone trimming the bottom of a door on a portable table saw, the entertainment value alone has to be way up there.
Tom
I like Green things
It was this year that you bought it.
I am not sure where my bosch table saw is anymore.
I have the dewalt, I got a great deal on it. Two tracks and clamps for less than the festool. Check home depot online.
I really have no complaints with it. I will say if dust collection concerns you then buy another saw. The dewalt hooked up to a shop vac is still dirty.
The dust doesn't bother me...
Discussion Starter · #9 ·
It sounds like almost everybody is using Festool. I did put a package together at Bob Marino's site I could not go for the 102" track so I did two 55" It came out to almost 800.00 with the connectors and a couple of clamps. The dewalt is less than 600.00 with the long and short track. Bob says I will be alright with the 2 55" tracks cutting 8' sheets. I guess if I decide to go Festool I will get the longer track when i get a few more bucks together.
It sounds like everybody is using Festool. I did put a package together at Bob Marino's site I could not go for the 102" track so I did two 55" It came out to almost 800.00 with the connectors and a couple of clamps. The dewalt is less than 600.00 with the long and short track. Bob says I will be alright with the 2 55" tracks cutting 8' sheets. I guess if I decide to go Festool I will get the longer track when i get a few more bucks together.
I have only used the Festool. I have heard that Dewalt and Makita are pretty good also. The Makita track works with the Festool, and is about 30% cheaper. Both of my tracks are Makita.
Artist and not a curator
Nope no use for it unless you want to be more accurate and better equipped for the job at hand. Festool is worth the money if you want to be clean.
Discussion Starter · #15 ·
Home depot is not listing the 2 track package on there site just the saw
Seems most of what I use my table saw for is ripping narrow pieces ( like jamb extensions for windows). How well does a track saw work for that application? I really want one, but like the OP I've wondered how much I'd actually use it.
Can I get an Amen?
Tom
Just out of curiosity, have you ever heard of anyone using a table saw to trim the height of a door?
TRMolnar said:
Ive heard that all three major track saws work with the dewalt tracks. Anybody know this to be true? Also can you cut on both edges of the festool tracks?
The dewalt had the tongue thing in the middle not on the edge as the makita and festool have. Not sure if they are the same size raised thingy or not but I wouldn't think they would work so well...
Theological Carpenter
I used to install closet systems If you buy one of these, you'll only have to haul that table saw out once in a blue moon. I have a track saw now, but didn't when I did the closets, and I can tell you that it would have made me so much faster and efficient.
1 - 20 of 140 Posts
