41 - 60 of 164 Posts
Administrator
Maker of Fine Sawdust
Would ya lookit dat.
There it is.
Sound strange.... a big breaker bar and my pipe cheater....
Not very glamorous, but seems our simplest,in this case leverage tools, are probably the most valuable.
I have one of those quart caulk guns for putting adhesive on floor joists. It has a "Y" at the end so it will ride the joist. I think at that same time I got a "stud tuner" to position studs and joists before nailing.
Never seen that Y thing...think I'll make some kind of coat hanger thing next time ....
Don't know what a stud tuner is.... but my 24 or 18 offset pipe wrench sure straitens studs out.
Best
Lazy Millennial
Carpenter
My multi tool, pin templater, and coping saw.
There's hundreds of uses for a multi tool, you all know that.
The templater is great for cutting baseboard to any uneven surface or if I have to match a baseboard without pulling a piece of existing base off the wall I can just conform it to the profile and carry it into the store, saves guessing.
The other carpenters at work don't see the value of a coping saw, I think they're crazy. I forgot it on a job recently and it's driving me nuts not having it in the tool box.
So you're saying you have a hard time coping without it?
The string is timeless and pretty self explanatory. I have found so many uses for a nail or even a well placed block of wood. The simple things end up being so useful and definitely the best bargains.
If I was pressed for a newer tool, I would place the laser first. I also have grown to love the track saw and pump jacks.
A mess of different/varied size big rubberbands.... for glue up.
Latex paint..... remember all the old (only) oil paints. Changed an industry/trade overnight.
The Fein MM for sure.
The other one that really surprised me is my little 12V Bosch Impactor. Nothing better for starting screws in tight spaces. I found this out while retrofitting drawer slides in an old kitchen. Those tiny screws are a PITA, and kept falling off the tip on my screw gun when I applied pressure. When finally started, it was difficult to keep enough pressure on the screw to prevent cam-out.
The little impact drivers solved both of these problems. Didn't even have a problem with the slides on a a bank of 7"-8" wide drawers!
Discussion Starter · #60 ·
Good one. And to get to the back wall for anything, I like to use hex heads + bit extensions. No messing around.
