1 - 20 of 30 Posts
Livin the dream...
What would you use to rip part of a fiberglass shower flange off. I want to do it fast but don't want to bust it.
I figured a circular saw would work as long as I would take it slow and make sure I was at full speed before contacting the workpiece.
I screwed up and grabbed a 32" tub with surround instead of a 30" and now I'm improvising.... :censored: :no:
Any of the above would work. I wonder if fiber cement shears would do the trick? No dust that way. Either way, you've probably spent more time thinking about it than it's going to take to cut it with and of those tools. I do the same thing....
Board Shortener
I'd probably try an oscillating multi tool first. Might be a bit slower, but probably do the job fairly quickly and with a little more control and less chance of grabbing and breaking off a chunk. Plus less airborne dust.
Livin the dream...
Discussion Starter · #11 ·
Probably, but I really don't want to screw it up and I just love coming on here and picking everyone's brain finding better ways to fix mistakes. :thumbup:
Remodel
Roughly 0% chance of cracking with a drywall route if you don't push hard. It's slow, the bits will gum up. but you don't have to support it. If you use an improvised guide, you can get a really straight cut. Otherwise, high RPMs, fine teeth, and a reversed blade are your friends - circ saw or angle grinder with reversed metal blade or ply blade.
Frankly, I tend to break thin plastic stuff of any kind if what I'm using has teeth.
1 - 20 of 30 Posts
