1 - 5 of 5 Posts
G
I have just installed a whole house pump rated at 2.2 bar.
Its for a friends house with one ensuite shower and main bathroom shower.
I didn't want to run an individual feeds from the hot and cold tanks to supply them so I thought it would be easier to pump the house house.
The problem is its too powerful, so the hot water tank gets empty in 3 showers.
Any ideas to reduce the output. I thought of putting gate valves on output pipes, will this damage the pump? Or is there a electrical methed that I could reduce the pump speed, such as a variable resister?
Try a whole house pressure regulator from Watts
# U-5-B it will lower the pressure and extend the water from the tanks.
? What is the PSI are you running?
What size are the tanks?
What is the temp on these tanks?
Bernie
G
Thanks Bernie
Would I fit one of these to the output of the cold and hot from the pump.
Not sure about the psi the pump is quoted at 2.15bar, which I think is about 31psi.
The cold water tank is 120 litres and the hot water I think is 115 litres
and the hot water temp is set at 60 degrees celcius.
cheers
sean.
Guess I will have to get a conversion chart, but too answer your question yes you would install such a regulator on the water main before the hot water tank.
Bernie
G
I think you have overlooked a bigger problem. You expect 3 showers with a 30 gallon tank (back to back i suppose)? Pressure isn't your problem, volume is. 30 P.S.I. for a domestic pump system is adequate (barely). If you drop the P.S.I., you will be able to pee harder than the shower. Want more showers, get a bigger water heater.
1 - 5 of 5 Posts
