I will be renovating an old two story house in Houston Texas built around 1910.The house is on pads and blocks. The house has shiplap on the inside only. The old siding is nailed to the studs. No water barrier between the siding and the studs. The studs are 2x4.To properly insulate the house I am thinking about removing the siding and blowing closed cell insulation against the shiplap which will leave a gap between the insulation and the siding. Then i am thinking of sheathing the entire house with osb along with tyvec and cement boards for siding. Does anyone know if the added strength to the walls will affect the house in a negative way.Houses here in Houston are affected by the moisture content in the soil.
