1 - 7 of 7 Posts
Just picked up a titan and worked like a champ for a few weeks now it won't load. Took it apart and all seems good.clean filters (rig and gun) No stuck dried paint or balls.put it all back together and same thing, it primes but won't load. The only thing I did not take apart was thew switch it's self (prim switch). Any help would be appreciated. Thanks
not sure what you mean?
My titan has an LED light indicating pressure.
At one point my I had the same problem you describe, but the pressure light was on. The problem ended up being the transducer. All I did was gently clean it, and it worked like new again.
I would give that a try.
I'd like to thank you for taking the time to help me out.it happened to be some old paint stuck in the prime valve area. That is the one place I didn't clean when I took it apart. Thanks again
1 - 7 of 7 Posts
