Time for earth to settle
39K views 14 replies 12 participants last post by  txgencon
Hi everyone and thanks in advance for your help.
I have a clien who has had a new sewer line dug through their front law. Last year, probably in the fall by the look of the mud.
It's probably about 8' deep and 50x20, the earth is raised about 18" above grade. What I need to know is the time line for this to sink back down, I assume most of it was in the ground and settled before the line was dug. If I scrape all this off with a bobcat will the lawn sink that 18" down the road?
Thanks again
#6 ·
re:
thanks for all your responses
the area was dug out in a front lawn to run a new sewer pipe from the home to the city line. there is no septic system.
the reason i assume its about 8ft down is that the sewer runs from the foundation does it not?
im not sure why its such a large area 20ft by 50ft, any advice would be appreciated.
#9 ·
I think what everyone is getting at, is that there's just no simple answer to your question. It just depends on too many variables.
A lot of the jobs we do, when compaction of backfill is not required, seem to need to sit through a complete winter in order to fully settle into place. The freeze-thaw cycles and the consistent leaching of meltwater down through the soil seem to help consolidate the material. But...with the mild winter we've had, things don't seem to be settling as well this year.
If your homeowner is in a rush, then the only thing you can do is dig it back up and properly compact it in lifts as you backfill. Otherwise it's a matter of 'wait-and-see'.
You may also want to find out who did the job in the first place, and see if they imported any bedding material (or other material) that would cause there to be excess backfill material.
#10 ·
A well placed soaker hose works wonders for dirt settling. I know of one supervisor that does it during dry spells on every home around the foundation overdig, with excellent results. As previously mentioned, how fast it settles is mostly dependent on snow/rainfall. This year It's been wet around here, & settling has been pretty good naturally.
It would help to know how much gravel fill the plumber used to install the new line. It could be he just didn't want to haul any dirt off.
Joe
#11 ·
I always tell people about a year depending on rainfall
That being said I have had a driveway settle 10 years after in clay
I have also had stuff settle in a couple months
I have a 4 foot pipe with hose threads that I can saturate a hole if i need to
Also when you mound up the soil the water runs off
It seems to work better to keep it flush after you dig
then it seems to settle a bit right away Letting the run off into your hole expediting the settling process
So I make a little stockpile if possible
