1 - 20 of 21 Posts
Wasting Time
Which would look best:
(1) Tiling flush with finished drywall, no grout-colored caulk (giving appearance that tile just ends in drywall?
(2) Leaving space for grout-colored caulk?
Thanks in advance for your suggestions.
It was an already existing shower. I just tore it out and redid it. I agree it's kind of small about 41" X 40"
I ws just counting your what appears to be 12" tile and i seen a 3'x3' finished opening....plenty of room to walk in and just say your in there...now actually trying to life an arm up to wash, aint really happening.. or i should say, it aint happening without getting flustered unless that shower is for Popeye's ole lady LOL!!
Do you know what the problem was why that bump out had to be built that way? and the shower not taken all the way out to the drywalled wall??
Wasting Time
Discussion Starter · #9 ·
You're very close, they are 13" tiles (40" rough opening). It's very tight. I'm not a little fella, so working in that tight spot wasn't fun.
Poor overall house design I guess is the problem. The open area of the staircase is immediately behind it, just can't go out any farther. Can't bring in the bathroom any either because of toilet. These people had the home built in 1965 and they together probably don't weigh any more than Olive Oil.:laughing:
on the outside corner, I always leave off corner bead and run bull nose tiles out to drywall edge and float out the space between tiles and drywall with durabond this allows you to plumb outside corner if not truly plumb no caulking or grout reuqired. :thumbsup:
Wasting Time
Discussion Starter · #11 ·
What I planned to do for the outside corner was to use some Schluter metal edging. I bet it would look nice doing it as you described. Had any expansion/contraction issues doing it that way?
bathroom guru
I use Schluter Rondec for corners like that all the time - haven't had a problem yet
The rondec has a bullnose profile - perfect for o/s corners
Wasting Time
Discussion Starter · #14 ·
Nope. no issues. I too use Rondec and Jolly for a lot of tile jobs.
I planned on using the Jolly in an oil rubbed bronze to match the shower. Any opinons about Jolly vs. Rondec?
Carpe Diem
I use Rondec and Jolly for 2 different applications.
I use Jolly as an edge finish or "cap" to tile. I cannot stand when guys have an exposed tile edge and finish it off with caulk :furious::censored::furious:. That's when I'd use Jolly.
You can see in the picture Jarvis supplied how he uses Rondec. That's the same way I use it.
You can interchange depending on how you want the finished product to look.
Question for you all. What if you run into a client that is adamant about not using schluter? I had a client who said he hated the way it looked. I had no choice but to end with tile edge. I used the sanded griot silicone to finish?
What other options are out there ?
Doctor Handyman said:
I had 45 pieces done, cut to 4 x 12 at $6.99 apiece.
More expensive than Schluter trim which is about $20/8', but I did not want that commercial look for my own bath.
I may consider buying the profiling blade that fits on a tile saw and some polishing pads for the next time.
That's a nice look. Might have to look into the blade myself. Thanks
1 - 20 of 21 Posts
