1 - 12 of 12 Posts
tiling baltimore
The customer is installing these Viega climate panels through out the entire house. As per Viega they only call for CBU over their system. A couple years ago I did work with a couple other guys that did this system with 1/4" Hardi and it has held up fine. The one floor was 1200 feet. I have about 600 feet to do and was going to use 1/2" permabase. So i was thinking what about a crack isolation membrane or Ditra. Just for my own curiosity I called schluter and they dont warrant Ditra directly over it.
http://www.viega.us/7119.htm
I cant really seem to find a definitive answer on whats best over this kind of heated floor. Any ideas and suggestions? thanks
We did a 1/2" Hardi over Thermal Trac which looks similar but is an MDF base.
MDF is inert and doesn't react the same way as wood does to fluctuations in concentrated heat like that.
No cracks.
PS: pressure test the system before you run the tile, but you probably already know that.
How's that for a non-answer?
Carpe Diem
1/4 CBU. Put some 6mil poly down and trace out the PEX tubes. Lay the CBU and place poly over before screwing down so you have a map to the tubes.
Since the heated floor can alter the floor temp quickly, I think a crack isolation solution is best. Probably NobleSeal as it's one of the thinnest.
1 - 12 of 12 Posts
