1 - 20 of 33 Posts
Hey Guys,
I will soon be putting down some tile in an old house that has the original pine plank subfloor, which I have never put tile on. Some of the gabs between the planks are 1/2"ish. How should I deal with this? Can I just apply mortar and 1/4" hardibacker the way I would over a plywood subfloor? It seems like adding plywood and then mortar and backer would be nice, but that sounds pretty thick.
Advice is appreciated.
-Cliff
Carpe Diem
An older home may not have the joist strength to handle a tile job. You first need to find out about the deflection. Chances are, you'll need an additional layer of EGP. If height is an issue, consider using Ditra instead of CBU.
I'm not professional tiler but I would put plywood down, even if it only allows for 1/4" plywood. Any added thickness would help with uneven flex with planks. Just figure out how much thickness you can allow for, then go from there.
I'm not too worried about the deflection. Another room in the house has tile that must be 10 years old and still looks fine. I wish I could see what is under it.
The wood floor I will be butting up against is about 3/4" thick. Maybe I could use 2 layers of 1/4" backer?
Fentoozler
I don't know much about anything - ask anyone, they will tell you the same - but if your floor resembles this one in any way ~ I wouldn't put much faith in it:
A clean slate is so much easier to work with:
The Remodeler
you should be worried about deflection, it'll cost you when the customer calls you back to fix all the cracked grout.... every year...
Don't base you decisions on the condition of a tile floor in another room of the house. There could be much better support under that floor.
Forget using 1/4" plywood anywhere under a tile installation, it doesnt add any strength to the subfloor, and it's soft core can cause more trouble with deflection. Minimum 3/8" CCX plywood (BCX is better) for underlayment.
Next, cement board is not meant to add strength to the floor, it's just a compatible surface to adhere tile to. So building up two layers of 1/4" backerboard is not a smart idea.
It's usually not realistic to pull out the planks and replace with plywood. It adds a lot of time and materials to the project, especially since the planks always continue under interior walls, load bearing, and non-load bearing. If the customer is willing to spend the extra cash to save 3/4" in height, go for it.
99% of my customers have no problem living with the height difference. A marble or granite saddle in the doorway makes a nice transition and alerts peoples subconscious to the slight step up into the next room.
Go with 3/8" ply over the planks, Ditra membrane (1/8") and then tile.
Carpe Diem
1/2" EGP is the minimum underlayment. That's over a proper subfloor.
However, if your joists don't meet minimum deflection ratings for the type of tile to be installed, none of this matters.
You may not care. However, there are minimum requirements for a reason.
Discussion Starter · #15 ·
Allow me to rephrase- The condition of the tile in the kitchen has me feeling comfortable with the JOIST deflection. The 12" tiles in that room butt up evenly against the same hardwood. That tile is over the exact same subfloor that is set on the same joists as the bathroom in question- it's all over an unfinished basement.
My original plan B was to cut out the planks and replace w/ 3/4" ply, but there wouldn't be joists to support the ends and there's way to much duct and knob-and-tube wiring to put more blocking between the joists to adequately support the edges of a new subfloor.
Alex, your plan sounds solid. Thanks for the constructive advice.
-Cliff
-Cliff
Carpe Diem
And how is that tile installed? My money is on a mortar bed :whistling
Look, do you want to do it right or just do it? Height is NOT what determines what is right. You've been given plenty of info to look at. You could do something goofy like 2 layer of 1/4" CBU or actually follow the recommendations of organizations that extensively test these methods.
What kind of installer do you want to be?
Carpe Diem
Cliff, I'm not tryin to bust your balls but you keep replying and saying things that don't make sense if you want to do it right.
The TCNA says MINIMUM of 1/2" exterior-glued plywood. You said 3/8" sounds good.
The TCNA says MINIMUM deflection of L/360 for ceramic, L/720 for stone. You said you're not too worried about it and there's too much in the way to add blocking anyway.
You suggested the use of 2 layers of 1/4" CBU.....
I'm not making up the minimum requirements, I'm just stating what they are. You are the one who seems not interested in following them. If you spent $10 to get a copy of the TCNA Handbook, most of your tiling questions would be answered. All you have to do is follow the recommendations. IF you do that, then I'd say you're trying to do things right. If you choose not to, well then you tell me what kind of installer you're trying to be.
1 - 20 of 33 Posts
