Usually the tile manufacturer will spec spacing as longer tiles will crown and can be tough setting flat in running bond pattern. If tiles are quality and you can check using a flat edge corner to corner on back of tile and see if there is space under flat edge in middle of tile then we set them 3/16 or 1/8th for rectified porcelain tiles which can be set closer.
I shot for a dime's thickness or 2 credit cards thickness for tile lippage. I always check the tiles before making suggestions on patterns.
Floor also has to be dead nuts flat for longer tiles or set on high spot and bring rest of tiles up to it.
