Best Tile Blade
  • T3 Razor
    Votes: 0 0.0%
  • Razor
    Votes: 0 0.0%
  • Stealth
    Votes: 1 50.0%
  • The Shield
    Votes: 0 0.0%
  • Pearl P4
    Votes: 1 50.0%
1 - 6 of 6 Posts
I've been looking at tile blades and I'm not sure what to get. The ones I've been looking at are 1. T3 Razor 2. RTC Razor 3.RTC Stealth 4. RTC The Shield Turbo and 5. Pearl P4 Turbo Mesh
Currently the main thing I want to be able to cut is porcelain tile. I see the T3 Razor is for "Staight Cuts Only. Tip up cuts, Clean out cuts, and shaping can damage the blade." Why do those type of cuts damage the blade? What are the advantages/disadvantages of a continuous rim or a segmented mesh type edge? It would be nice if they had some type of chart with a star rating to compare the blades.
Don't have any experience with the blades in question, but anything other than a straight cut will put unequal pressure on the blade and cause the blade to warp slightly. This ends up causing vibrations in the blade which transfer to the tile and cause splits in delicate tiles.
I imagine a "tip up cut" would be lifting the tile off the carrier deck to get a deep square notch cut. This can also cause uneven pressure on the sides of the blade, thereby causing warpage. I personally do not like segmented blades for this very reason. They are much truer to start with, and if you baby them will stay truer, but they're very sensitive to side to side pressure, and warp very easily.
Yeah that makes sense. I do a lot if cuts like that on the T3 with no issues.
1 - 6 of 6 Posts
