1 - 12 of 12 Posts
I read a old finehomebuilding mag that had a article about using a stick to transfer measurements to piece if cardboard and then you transfer that to your work piece.
The example was a bow window . Does this really work? Of course I can't find the mag and would like to try it out next week. I think the author said boat builders used it when building wood boats.
The name may be wrong to. Going off what I remember.
Yeah can't accidentally read your marks an inch short or whatever. Woodworkers use it a lot. Prevents measuring errors and having to pull your tape out for every cut. Also makes things more precise, less chance of being slightly off the mark on identical measurements.
Reactions: Gary H
Discussion Starter · #9 ·
I always wanted to try it. And of all of the construction books I got this is the only reference I ever seen of this method. I will be sure to get picks and report back how this method worked out.
I thought of using lath and hot glueing the pieces together like the solid surface installers do. But this method of the story pole elinates the need for the glue gun.
keith mathewson said:
Ticking is NOT the same thing as a storypole. Storypoles are used to layout linear diamentions and ticking is used to transfer irregular diamentions to a piece of material to be cut to fit.
I realized that after he posted that article, we use story poles for siding, and elevations.
Remodel
I think the tic stick works well for doing something like fitting doors to an opening in old buildings. It's slower than taking cardboard or building paper and just taping together a template on a floor.
Accurate marking and alignment is fairly critical.
Tick sticking is definitely not the same as a story pole.
I have done it a bunch of times, usually when installing a continuous countertop into an existing bay window or some other unusually shaped area.
Very simple to do and works everytime
1 - 12 of 12 Posts
