1 - 6 of 6 Posts
We're using jack hammers to take up ceramic tile in a local shopping mall. The hammers are only popping up the tiles in most places, and aren't taking up much of the thinset.:censored: Does anyone know of a quick way to remove the thinset after we get the tiles popped off?
Thanks!!!
Thin Set Removal....
If you want to make your life easier, thow away the jack hammers and go rent a riding floor scraper (like a Bronco, or Renegade or National machine). They will get the tile up much quicker and take more of the thin set with it. To get the rest of the thin set off, you may need to rent a concrete grinder or a drum scarifier. Hope that helps...
tile contractor
For a mall, a shotblaster is the thing to use. You'll take up a few thousand feet of thinset a night. Trust me-- I did this work back years ago for a company called Total Flooring out of Florida. We went all over the country doing new mall construction, as well as renovation.
Don
you best way is a floor grinder if its under 1000 sq ft if over im gonna guess there is an attachment for some sort walk behind skid steer
tile contractor
This, I believe, is the machine that BoneCrusher was talking about for tearing up the tile:
http://www.blastrac.com/en-us/pc-121-27-bms-220bx2.aspx
And this is what I was talking about for the thinset:
http://www.blastrac.com/en-us/pc-799-6-1-15d-super.aspx
Now, don't let the prices shock you-- both machines are readily available for rent in most big municipal areas. Of course, if this is something you do on a constant basis, it might be worth your while to looking into purchase. Both these machines could very easily pay for themselves rather quickly if you have the work for them.
1 - 6 of 6 Posts
