541 - 560 of 4478 Posts
I did this with a smaller mesh type blade. Works great.
This is the ATS blade someone had posted about. What's the mesh blade you have? It chipped a little more than I would like, might just be the quality Lowe's tile though.
Always Learning
I have that blade also and found it chipped more than I like also.
This is the one I used.
4.5"-5/8"Dry/Wet Thin Diamond Circular Saw Blade Mesh Rim For Cutting Porcelain https://www.amazon.com/dp/B076Q441M8/ref=cm_sw_r_cp_apa_i_vM7uCb2QX5JJY
It took a few adapter rings to get the arbor to fit tight but the cut quality was good.
Rib dinner tonight at a local place called Greg's.
Hell yeah. Nice spread and good beer choice brother
Doing two briskets in a row - got one on now for tomorrow and I'll start one tomorrow for Sunday. Ribs both days - and chicken tomorrow.
Sent from my SM-N920V using Tapatalk
John the Builder
Salad looks a little weak. Croutons soggy ?
Ribs look real good
I had worked over the salad pretty good by the time the ribs arrived.
Never tried the croutons, decimated 1/2 loaf of that bread and probably a 1/4 pound of butter.
https://youtu.be/Ajcm-2keo38
I was thinking of this today and decided to see if one of my continuous rim blades I have for my grinder would work. I used the adapter ring that came with the ats blade and it fit perfectly. The cuts came out much nicer. I had the saw turned down to around 2
Do the mesh ones give a better cut than standard continuous blade? Better cooling?
John the Builder
I sorely miss Texas style ribs.
Always Learning
In hard porcelain yes. They cut very well and relatively smooth. For the mesh blades you want to run them on full speed. Actually I bought the Makita 5" dry cut saw after that video because it runs at 12,000 rpm which matches the blade better vs the 6500 +/- that the TS runs at. That Makita saw has a track adapter that runs on Festool/Makita tracks.
World's Tallest Midget
I love puzzle cars/trucks.
There was a VW Jetta running around the next town when I was in high school that was a different color on every body panel. Only years later did I learn that was actually a factory option.
really?, there is one near me that I thought the guy was being creative
