How would you guys go about making a 135 degree outside corner joint with thinstone? I know some companies make them but not the ones from my regular supplier and there are a LOT of these corners. Its mosaic pattern.
The best I have been able to come up with is to take some of the larger pieces, cut them down the center(ish) and bevel both pieces so I can get a tight miter. It's probably unnecessary to do the split as long as I can get two pieces that are similar in height and color. To avoid a continuous grout line I would also do some corner butts
. Will this look like total dogjob to anyone that doesn't work with stone? I figure I can keep the grout lines to less than 1/8" if I'm careful.
See less
