Sketching some framing into a plan, one to be built outside San Antonio. It is a plan from Alan Mascord Design Associates, and the plan shows engineered trusses.
Engineered trusses are a huge no-no in the S.A. market for custom home building. Commercial, light commercial, and production builders use them right an left, but few if any of the custom builders will use them.
So I'm examining the structure to see if a hand-framed stackup job will work, and how the details might look.
Rafters need to be 2x8 most everywhere due to large spans, figured using the 5 psf ground snow load, with some smaller spans using 2x6.
The design with trusses has a roof arrangement having a 12" heel height, which makes for a good eyebrow line with the 24" overhangs, so I did the bearings with the 2x6 ceiling joist frames being plated with a single 2x6, and the 2x8 rafters getting a full birdsmouth. The 2x6 rafters get a smaller one with about a 2" seat cut.
First pic attached shows this.
The garage is different, in that its ceiling spans are longer, requiring a ceiling frame of 2x10 joists. The 2x8 rafters, raised off the 10/0 wall plates, have no birdsmouth cuts, and bear on blocks cut from something. I say "something" because I am not sure the blocks should be from the #2 SYP stock used for rafters. But maybe that is OK.
Second pic shows the garage bearing situation.
Anyone see any issues?
Having crawled into a few attics in the S.A. area, I have seen a lot of roof frames where purlins and purlin braces are used, so as to be able to downsize rafter sizes. My second pic shows where there is an opportunity for this in the garage. Should I do this so as to be able to go down to 2x6s?
