Greetings! I was hoping a few of you guys might be able to help me out.
I have 18' feet of exterior wall damaged by termites. Top Plate to bottom will need to be replaced. Exterior siding will naturally be torn off as well.
The ceiling has been clipped to approximately 10' and the joists/rafter connection is 10d (x4). I am needing to support the roof while replacing the exterior wall; a few hours, tops. The floor under the majority of the relevant roof section is slab concrete, allowing any form of support and the rest is hardwood with sufficient floor joists support.
I am Needing a proper way to secure plumb bracing (temp wall) to an 8:12 slope that will properly support the roof weight as well as negate outward roll tendencies. I am hesitant to brace directly under the ceiling joists as the x4 10d's are designed primarily to hold the rafters postioning and not to also carry the dead load of associated roof square.
I have considered attaching a reinforced, double 2x6 perpendicular to the rafters and directly under the joist intersection to act as a cleat. Then placing a 2x6 temp wall with double top plate under the cleat, but angled properly to sit flush with the rafters. This would appear to handle the downward roof drive, but makes me a bit nervous regarding the potential outward thrust. then again, as long as the joists remain in tact, I am not confident how it could roll.
I also considered removing the exterior soffit in hopes of revealing the rafter tails. Simple wall under the tails and pull the damage inside the house and replace from within as well. But I am not confident the tails will hold the weight. I have never tried it.
Anyway, could use some ideas. As I said, once installed, I should have the wall back in place shortly. I will be unable to prebuild prior so I will be throwing sticks in.
Note:
Ceiling Drawn/Stamped by SE
Approved 2009 IRC
Inspections will be done
Joists installed prior to termite damage being revealed- Tried to save some rock- Rafters have dropped in some areas due to rotted top plate. Ceiling joists installed level (creating possible wave in finish taping but only visible if pressed against the wall and looking up- Had to choose the lesser of two evils) 'Righting' the rafters now will throw the ceiling joist out of level.
I have also considered righting the rafters while replacing wall, cutting the joists in place, reinstalling with butt joint and Plywood Gusset. This is the last time I install with joists with face overlap!
Ugggh.
Photos attached and thanks for you time
I am new to the site so feel free to educate me if I have posted incorrectly or missed something.
Note:
Approved 2009 IRC
