In my area almost all neutrals are earthed.The supply neutral must be Earthed.... aaaaaah, no.
Sent from my SM-T380 using Tapatalk
400v series.The supply neutral must be Earthed.... aaaaaah, no.
The neutral and the ground are essentially the same thing. Main difference is the ground isn't suppose to carry current unless there is a fault in the system, and the neutral is a current carrying conductor. They are bonded in the circuit breaker box.Isn't the neutral tied to ground at the transformer?
Mike.
_______________
There are exceptions, but it's in odd commercial supplies mostlyThe neutral and the ground are essentially the same thing. Main difference is the ground isn't suppose to carry current unless there is a fault in the system, and the neutral is a current carrying conductor. They are bonded in the circuit breaker box.
I presume as such. I didn't see any unique specs that prevent this VFD from being a good solution for my use. Hope I asked the correct questions...Isn't that bonded?
An Earthed neutral is a ground.
yesI wanted to update my gule game,, did I get the right one:blink:
Well can't get a pic up,,,
it's this one, https://www.gluegun.com/collections/pam-glue-guns/products/pam-hb-220-glue-gun
I was replacing my struts and the bolt was not coming off the frame after trying torchs, grinders, sawzall, and hour later I said " screw it I need a die grinder " took 1 min. really suprised me when the strut dropped. really well priced compared to Milwaukee and dewalt. well worth the 100 bucksI think I needed a die grinder:jester:
I got an email offer on your milwaukee 8 gallor extractor. How's it holding up? do you recommend it after this summer? I'm going to check it out on Monday.Let us know how you like that new chuck on that drill.
Mike.
_______________
I got an email offer on your milwaukee 8 gallor extractor. How's it holding up? do you recommend it after this summer? Im going to check it out on Monday.
Sent from my SAMSUNG-SM-G891A using Tapatalk
