2641 - 2660 of 2728 Posts
Administrator
Maker of Fine Sawdust
That would work. I've had many door manufacturers ask me to buy their doors and that's the first thing I ask them. Do you pin your doors in a squarer and then just take them out without the glue curing. I haven't had any of them say no. No sale. I tried some doors that were pinned by a local company and the joints cracked the paint soon after. Not only do they pin instead of clamp, they don't put glue in the shoulder, just the tenon. So there is a non glued area that is subject to movement which will crack a painted finish.
I guess if the rails are perfectly cut, it won't over press them out of dimensions.
Focusing on solutions.
I also picked up the stile glue spreader. Won't be no starved joints coming out of our shop. I quit having cracked joints once I made sure to get glue on all surfaces & a little squeeze out on the face.
How does it maintain door dimensions...or do you need to account for over cutting panel slots?
I haven't had the chance to use it yet, but the way it looked in the video, you leave the stiles a little proud during assemble & as it clamps, it first pushes the stiles even with the rails then clamps the rails tight & square.
Administrator
I use a little acid brush to spread it out on all surfaces of the tenon and shoulder. Get a little squeeze out.
Also got this 1965-ish Craftsman 1/3 sheet sander. The plastic jacket on the cord was actual brittle so it had to be replaced. Works fine now. Probably never use this either, but rescued it from going to the dump. Its on the shelf with my 10 other sanders now.
Administrator
No trick. The site is broken. Sometimes it works, sometimes it doesn't. It'll be transferred soon enough.
Contractor
Rescued this cordless variable speed reversible drill from a dark cluttered corner of my sis-in-laws garage. Her hubby owned a furniture repair and upholstery business for many years. I’ll probably never use it, but at least it has a home.
Hey, I've got one of those.
Sent from my SM-G970U using Tapatalk
I do too, but shouldn't need to going forward. Here's the glue spreader. Cut your profile on the plastic block & it applies it to both stiles at the same time. https://www.jamesltaylor.com/product/stile-spreader-guile-applicator-160b/
I've spent a bunch of money trying to speed up the process. We've been building about 100 doors a month lately. Truth be told, trying to get it where my wife can do the door glue ups while I'm doing more involved projects.
