1 - 3 of 3 Posts
outforablast
Blasters normally use a ton of Tape and we found out that the gorilla tape does the best protection and the adhesion is awesome but down side is 12+ bucks a roll 35 yards but we used to need to double layer the windows with normal duct tape so really were at least saving the cost of the labor But were also blasting at 120 psi
I thought others were also using shrink wrap tape? Not sure what
PSI they are blasting at though.
Online for around $14 for a 2"x 60 yard roll.
Trial and Error Opperator
On windows I some times use shrink wrap tape But!!! You got to put blue tape under it and leave a little gap between the rubber and the window ( about 1/4") so it will stick around the edges. The blue tape keeps you from pulling the windows out when you take it off lol We also use gorilla duct tape a lot to HD has the 80? LNFT for around 8$$ I blast with 120 psi but the shrink tape will not hold up like the duct tape so try to stay off it as much as you can
Ps about the windows on the trucks I posted
The windows are not etched its dust
1 - 3 of 3 Posts
