Use a setting type compound. Much stronger than the bucket pre mix mud. :thumbsup:
I would do this on small stuff, no bigger than 4" square. After that a California patch just isn't reliable enough IMO. I have repaired too many that if they had used just one vertical backer all would have been fine. A piece of scrap and a few screws is cheap for insurance.Next time you cut a patch make it 1 inch larger than the hole. Remove 1/2" of the "rock" 4 sides, cut from the back, do not damage the face paper. Bed the hole with setting compound, place the patch in the hole, knife the 1/2" flange. Apply finish compound (spackle for you seaboarders). This makes the repair with no tape or backer.
Tom
Better you than me dude!!! My magic wand is out of order ! Laminate the entire wall with new board for a [flat] finish.I have attached some photos of what I am left with because I may be overstating how bad it is. The long large sections came out ok and reasonably tight. It was the thin sections that essentially were to cover the small vacancies left by where a wall that was removed met the adjacent wall that were the most trouble. There was not much for the drywall to "Bite onto" and the narrow gap made hammering any new lumber to support the drywall fairly impossible.
You can see from the pictures the long pieces and the narrow one.
My biggest concern is the difference in depth as I am hoping to avoid any tape lines showing on the wall where the repairs were made. Your continued feedback is appreciated and hopefully the pictures give a better picture of how good/bad the joints are.
I always make my blowouts with about 11/2'' all the way aroundNext time you cut a patch make it 1 inch larger than the hole. Remove 1/2" of the "rock" 4 sides, cut from the back, do not damage the face paper. Bed the hole with setting compound, place the patch in the hole, knife the 1/2" flange. Apply finish compound (spackle for you seaboarders). This makes the repair with no tape or backer.
Tom
shim that new board, looks like 5/8 would have worked better. either way you can prefill gaps with durabond, tape, and bust it out and it should be okI have attached some photos of what I am left with because I may be overstating how bad it is. The long large sections came out ok and reasonably tight. It was the thin sections that essentially were to cover the small vacancies left by where a wall that was removed met the adjacent wall that were the most trouble. There was not much for the drywall to "Bite onto" and the narrow gap made hammering any new lumber to support the drywall fairly impossible.
Busting out bastard butts ??? Have fun.:thumbup:shim that new board, looks like 5/8 would have worked better. either way you can prefill gaps with durabond, tape, and bust it out and it should be ok
Mix it with hot water and you won't even get it all mixed.FRAME2FINISH said:Just mix it and leave your trowel in it , then go drink a soda.
You'll swear it only took 3 minutes.
I use 5 all the time. Mix it in the same room and you're good to go. Use it when you have a small repair and want to put more than one coat (anything to minimize sanding). Also, if you get in the habit of using a larry light when you apply, that makes it even easier to double-ckeck your finish.Where on earth is 5 min used? I have used it once to patch a hole and even with cold water by the time I got it mixed and patch the 1x1 patch it stated to set up and wouldn't have spread at all. I would hate to think how quick you have to work to get through a bag of it.
