1 - 20 of 35 Posts
Hi. I've got a tapco pro 14 brake, 10'6" long
My problem is, when I bend a 90 degree piece the ends are a little tighter then 90 and the middle is a little looser then 90. I've be trying some adjustment and nothing seems to help. Is something worn? Or adjustment issue?
Thanks
Ya, I've read that before and also watched a YouTube video about that.
When it talks about clamping the piece in there and then being able to slide it, there is no way to make mine loose enough to slide. The bolt that goes through the link, at the loosest setting, is about half way up the slide. Not sure if that makes any sense, do I need to trim the piece of rubber in there so that there is more adjustment?
Butcher of wood and metal
My Black Max bends the ends past 90 too. Just got use to bending them back problem solved. Sometimes wonder if it is not because the may be less bend resistance at the ends then the middle?
KemoSabe
This has always been my theory.
Have you tightened the hex bolts on the arms? We have a good tapco rep in our area one call to him and he is there same day for a tune up
Dumb question Eric ,but you are lifting up the bottom to hem right.
Yeah, close the jaws, position the piece in the pocket and pull up on the handle. Small pieces close nice and tight, but the long pieces just don't close up as tight as I would like.
I'm wondering if any of this has to do with that rubber strip being worn out or oddly compressed?
Yep. Basic physics. The center is surrounded by a bunch of stuff; the ends aren't. Watch any experienced brake man, and he does the compensating stroke at each end without even thinking about it.
I've always run my hand starting at the center and gradually applying pressure towards the end to kind of straighten things out. Just par for the course?
1 - 20 of 35 Posts
